Finished updrilling the bolt holes for main spar root attach angles. Had to move outside to fit the spar under my benchtop drill press.
Started updrilling the bolts on the left outboard main spar. The slot in the lock lever guide is a bit too small so will need to file it a little to get the lever in the correct place.
